Clears the inline statistics for the selected port to zero.
| all | Specifies all ports. |
| port_list | Specifies one or more ports or slots and ports. |
N/A.
Use this command to clear all the information displayed by the show inline-power stats ports port_list command.
The following command clears the inline statistics for ports 1–8 on a switch:
clear inline-power stats ports 1-8
The following command displays cleared inline power configuration information for ports 1–8:
show inline-power stats ports 1-8
Following is sample output from this command:
STATISTICS COUNTERS Port State Class Absent InvSig Denied OverCurrent Short 1 delivering class3 0 0 0 0 0 2 delivering class3 0 0 0 0 0 3 searching class0 0 0 0 0 0 4 searching class0 0 0 0 0 0 5 searching class0 0 0 0 0 0 6 searching class0 0 0 0 0 0 7 searching class0 0 0 0 0 0 8 searching class0 0 0 0 0 0
This command was first available in ExtremeXOS 11.1.
This command is available on the PoE devices listed in PoE section of the Switch Engine v33.1.1 User Guide .
